68-9 b-BODY BODY PARTS ,
joel
7:41 AM
edinboro pa
Feedback: 20 / 0 / 0
b-BODY BODY PARTS
e mail
68 charger doors fair cond some seam rust no rot through 125.oo ea with glass, clear,
69-70 charger doors various conditions 50-125.oo
66-67 coronet trunklid some small seam rust 100.oo
69 coronet flat hood excellent cond [make your own ramcharger] 200.oo
66-7 coronet left fender fair cond rust in very lower dog leg driver qual. 50.oo
69 roadrunner ,gtx front fender no rust has large dents 75.oo ea . left and right
68-70 charger trunklid large seam rust 25.oo
63 dodge trnklid good cond 125.oo
63 dodge hood exc 100.oo
located in n.w. penn NO SHIPPING on body parts
parting out 68/69 roadrunner /satellite/gtx
points distributor 383/400 75.oo
k frame 100.oo
lower control arms for sway 125.oo
sway bar 50.oo
tailights 25.oo ea
tailight housings 25.oo
headliner bows 50.oo set
dash parts green , gl. box door 50.oo
wiring harness 100.oo
rear window trim 150.oo
front window stainless 100.oo
68 plymouth stainless dog dish hubcaps excellent 150.oo--4
69 roadrunner/gtx parts
a pillar plastic trim typical attaching pc. broken black 25.oo ea
69 roadrunner tailight lenses nice driver or polish for show qual 25.oo ea
69 roadrunner tailighjt chrome bezels some pitting 25.oo ea
68 roadrunner tailight lenses 25.oo ea
68 roadrunner tailight chrome bezels some pitting 25.oo ea
bumper brackets front 25.oo ea
69 rr/satt headlight bezels 25.oo ea
hardtop door glass non tint 50.oo ea
hardtop qtr glass non tint 50.oo ea
door window regulators 25.oo ea
qtr window regulators 25.oo ea
post coupe qtr glass non tint 100.oo ea
post coupe post stainless 100.oo pr
post coupe inner headliner steel headliner support trim 25.oo ea
post coupe interior qtr panel steel upper door panels 25.oo ea
post coupe door seal stainless 50.oo ea
hardtop rear upper door panels steel 25.oo ea
vent window frames some pitting 25.oo ea
vent window rubber seal 5.oo ea
vent window glass 20.oo ea
69 roadrunner tailights with bezels small pitts , fair cond 25.oo ea
69 rr/gtx tailightqtr. extensions 50.oo ea
black int. parts
heater box non a.c. 100.oo
vent box for driver side 25.oo
69 b-body roof cut oversize cant ship 100.oo -175.oo
rear window 150.oo
front windshield stainless trim 100.oo-set
rear window stainless trim 100.oo set
vinal roof trim 100.oo plymouth or dodge 68-70
headlight retainer rings 5.oo ea
dash switch panel with switches 100.oo
sidemarker assemblys with reflector and retaining plate 25.oo ea
glove bod lid black,blue .green 50.oo ea
heater control [non a.c. ]50.oo
steering column filler pc[under col]black ,,25.oo
69 gtx tailight lense 50.oo ea
69 gtx tailight bezel pitted 50.oo ea
69 gtx rear finish panel pitted 50.oo
wiper arms 20.oo ea
inside mirror 20.oo
manual steering box 100.oo
8 3/4 rear axle housing and axles 125.oo
14x5.5h magnum 500 wheels [road wheels ]need restored 20.oo ea
10 inch rear drum parking brake parts 20.oo
11 inch rear parking brake parts 20.oo
70 rallye dash frame 200.oo
70 rallye dash cluster from 70 roadrunner missing tach 200.oo
heater vents black 25.oo ea
heater hoses [non a.c. ]
68 rallye dash harness 150.oo
69rallye dash wiring harness 150.oo good cond
69 CHARGER /superbee RALLYE DASH parts
69 charger/ superbee complete rallye dash plastic , nice cond , 200.oo
69 charger/superbee rallye cluster used , good circut board, clock no tach, 200.oo
68-9 rallye dash frame with 3 speaker cutouts 150.oo
69 CHARGER /superbee RALLYE DASH frame poor cond 100.oo
ASHTRAY[COMPLETE ] 25.OO
727 small block trans 125.oo
727 big block trans 125.oo
70 coronet R/T 500--parts
coronet 500 dash pcs, inquire
hood saftey catch assy 25.oo
70 coronet 500 chrome qtr panel insert chrome fair cond 40.oo pr
rear qtr extensions 30.oo ea
70 roadrunner parts --------------------------------------------------
grille =poor cond 25.oo
grille broken tabs and a couple of grille bars missing 10.oo
lower grille plastic (part between bumper and grille) 75.oo
filler piece between bump. and grille (steel) 50.oo
70 383 H.P. motor/ not running/ missing = valve covers/carb/exh manifolds/400.oodated 10 of 69
k-frame 100.oo
lower control need sand blasted 125.oo pr
power steering box 50.oo
8 3/4 rear axle housing + axles 125.oo
door glass for hardtop tint 75.oo ea
door glass for hardtop non tint some scratches 50.oo e a
qtr panel hardtop glass non tint 50.oo ea
rear glass 150.oo
68-69 b body steering column 4 speed /floor shift manual steering 200.oo
8 3/4 66-70 b body axles/housing + axles 125.oo
b body axles only pr -50.oo
11" backing plates 50.oopr
10 " backing plates 25.oo
10 " backing plates =complete 50.oo
located in edinboro pa , 16412
Joel,
That's a heck of a list. But..... what I'm looking for is the toggle or link that goes between the brake pedal and the booster rod. 68, 69 or 70 b body will work.
thanks,
Mark
you have to private message me [click on my name on the left, and click on private mesage, ] rules say i cant post it here
do you still have the points distributor>
condition?
part number?
thanks!
i have a bunch of points dist. which # are you looking for,
pm me
i have many points dist. let me know the # you need
I need all the hood latch parts for a '69 Belvedere/Satellite/RR
Do you have vinyl top trim for plymouth and dodge? Because they are different pieces. I'm needing a Dodge set for a 69 bee.
Do you have a right rear frame rail. I need the section from the bumper to just in front of the spring shackle.
bumper brackets for which car? fronts or rears? thanks, joel
