verdelaw
Hi I'm fairly new to old cars in general, so please forgive my naiveté. I wanted to check to see how these old drum brakes were doing and figured it wouldn't be too difficult. I've disassembled new (disc) brakes on late model vehicles so I figured this wouldn't be too hard.. wrong!
I pulled off the dust cap, removed the cotter pin, removed the star shaped cotter pin retainer, removed the nut, and pulled on the hub.. no joy. So I used a hub puller and got it off. Great! This is what I saw:
![my drum.jpg my drum.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/216/216543-191a00c35def3be8aac308805aada374.jpg)
It seems to be missing the lever that engages the adjuster cog at the bottom? Like it shows in my service manual? Like it looks like in this picture I pulled off the web?..
![correct drum.JPG correct drum.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/216/216544-8222f127202a4e96f45b9ae6c89b52c6.jpg)
Don't I need that lever?... I adjusted the cog at the bottom a few (12) notches anyway to see if I could get the drum back on.. and it went on, but popped out the bearings? And a big washer that looks a little bent (perhaps I did that with the drum puller?) and has a tooth in it that corresponds to a channel in the spindle? Now I'm confused. See bearings and tooth-washer at bottom:
![pieces.jpg pieces.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/216/216545-1dded0962bde024af85a92f42f852def.jpg)
Do I need to replace this washer? The bearings? Do I need the lever that I think I need that is supposed to hold the adjuster cog? Confused. Any help appreciated. Mockery is acceptable if useful guidance comes with it.
