danf_fl
I am installing electric headlight door actuators.
I finally got some time to work them in.
I'm tapping off the low beam light wire to supply power to "open", and running a wire to the start block terminal for power to "close".
I would like to put an in-line fuse in the wire to the start terminal, but the instructions do not include what amp fuse should be used.
The reason for the fuse is that if something should go wrong with the actuators, the fuse blows, but I still can make it home versus having something ground out the terminal.
