munger77
Hi everyone, I could use any help you can muster up.
tomorrow I will start troubleshooting electrical gremlins in my 1968 satellite convertible with 440; originally had AC. Runs and drives great. Wiring harnesses are new up front and in rear; 'reconditioned original harness in dash bought off ebay', and not sure of the turn signal switch - - all wiring was installed by a shop that claimed they were experts, but they were charlatans/rip off artists. I'm new to the area and a bit gun shy about taking it to the next set of liars. I trust this forum more than anyone so here goes:
1. brake lights are on even with key out of ignition, and only driver's rear + front right signal light go on when the brake pedal is pressed. Switch itself seems to work fine.
2. Only gauge that works is alternator. No other gauges work at all.
3. Blinkers seem to work fine front and back, but only driver's side dash indicator lights up; turn signal cam/cancel does not work correctly. When changing lanes it is real hard/ a lot of resistance to re-center the turn signal lever, so I accidentally drive with a blinker on here and there.
4. all headlights and tail lights seem to work; hi beams go on and off fine.
5. Horn did not work since i've owned it. Last week I drove it a few miles, started it back up coming out of a store and the horns were on; couldn't figure out why. Sounding all the time. Started it 3 times and they came on and stayed on so I disconnected them at the point of the horns and drove home. Got up the next day and the (2 month old) batter was drained completely. Steering wheel is original, kind of old and has some cracks in it; I may replace with a wood rim wheel and press button horn.
I have a wiring diagram but Where do I start??? I've read sections on this forum for several months here and there, but is there a thread for how to troubleshoot this stuff, and what NOT to do?
