I am looking for both pieces of trim. One for the driver's side door (the piece that sits on top) and the other one for the driver's side quarter (shorter piece, on top). Any help/leads would be appreciated.
I wasn't sure if the hardtop was the same trim. Thanks R/TThe door trim is the same as a hardtop... I had to find a door trim for my Coronet R/T Vert...
I don't know if Dodge & Plymouth door trim are the same...
Quarter trim will likely be a little harder to find...
I have the right side only.No problem.. Do you still have the original trim? A good trim guy can fix stuff you wouldn't believe... I wouldn't spend much on fixing the door trim but the quarter trim might be worth fixing...
Standby one,, I’ll take a couple picsCould you post pictures so we can see if it's the same as Coronet trim?
That’d be awesome. Let me know whenever you get to it. Thanks man.I just dug up a rear trim & I can verify it's the same... View attachment 1036426View attachment 1036427
Ok, thank youI will look and see if I have a single. I know for sure I have complete sets.
No worries R/T, I very much appreciate the effort.I checked my storage, the single I have is for the passenger side.. Sorry.. Good Luck, I'm sure someone here will get you hooked up..
BTW 68-70 Plymouth & Dodge are all the same... Rear trim is vert only but again 68-70 Plymouth & Dodge..
