billy garrison
New Member
does anyone know if a engine built on 12/26 1967 could make it into a car built on jan 4th 68.the engine was built in Trenton Michigan and car was built in st. louis
thank you sir I found it and it matches last 8 of vin I knew it was orinal motor now I have to convince appraiser thanks again billy68's had VIN numbers up top by the bellhousing and oil sender. If it matches the car you'll see a stamp up there.
Plausible but only part of the puzzle.
Wow !I would have no way. My engine cast 1/21 assembly date 2/16 car build week 3/8.thank you sir I found it and it matches last 8 of vin I knew it was orinal motor now I have to convince appraiser thanks again billy
Back then the 'Teamsters' ruled!! Driving semi's all over 24/7, holidays(?) nah!! Kinda unlikely, tho.Wow !I would have no way. My engine cast 1/21 assembly date 2/16 car build week 3/8.
-------68's had VIN numbers up top by the bellhousing and oil sender. If it matches the car you'll see a stamp up there.
