19 69 GTX
- 2:22 AM
- Apr 30, 2016
I've 68 383 HP engine and trans out of a 68 Plymouth Roadrunner. Original 40k miles on engine and trans. Has stock pistons and rods. It had new crank and rod bearings installed plus windage tray. Heads are are 452 with Milodon stainless steel valves. Heads had mild poet work on both intake and exhaust. Has adjustable rockers arms as well. Mopar hydraulic .484 purple shaft cam. Has double roller timing chain and hv oil pump. The trans is the original trans as well Has shift kit and the original torque converter. Engine ran great when pulled a little over a year ago. Been stored in garage since. Bolt in go just add what's needed. 2500.00 takes it and shipping may be possible. Located in Terre Haute Indiana
