rmchrgr
I posted this on Moparts but did not get much response, hoping I can get some more input on what what I am doing here to try and confirm if will work and be safe. I changed some things from my post over there to try to make it clear. See pics below.
Generally speaking, aftermarket ignition systems like MSD want to see the full 12 volts while cranking and in run. The OE switch functions do not allow that to happen because of the OE ballast resistor bypass function so when you start the car, there is a moment when there is no voltage coming through the IGN 1 circuit.
So what I am doing is "tying IGN 1 & IGN 2 together" right behind the switch and then tapping the red ignition box signal wire into that circuit. In this application the ignition box drives the coil and there is no ballast resistor so those output wires have been eliminated.
I am working with an aftermarket wiring harness so imagine the pink wire is the OE blue for IGN 1. The small red wire spliced to the looped brown IGN 2 wire is for the ignition box signal.
I left the molded plastic switch connector off to show how the wires connect to the switch terminals.
My concern with this setup is that the IGN 2 terminal on the back of the switch is always going to be hot even when the key is released to the run position. I believe this is what aftermarket ignitions generally want but I am not sure if wiring it directly behind the switch this way will overheat the contacts inside the switch.
If that's a distinct possibility, can anyone recommend a different/better place to make the connection between IGN 1 & IGN 2?
I have seen where a relay can be used to handle this situation but I'm not sure how to wire it properly without the ballast or coil outputs.
Thanks for any input.
Greg
Greg
