68 Non-rally tach wiring
doberjoe
2:55 AM
Seattle
I have factory non-rally tach in 1968 GTX, trying to figure out the wiring. Believe that Dark Blue wire connects to the terminal on the left (12V power from the fuse box?), and the other stud on the right (with the black plastic cover threaded on) receives the Grey wire for the tach signal (negative side of coil coming thru firewall hole).
Some photos I've seen show a spade lug on this, but mine doesn't have it, wanted to make sure I had the wiring correct before I hooked it up and burnt something up.
Can someone confirm this or show a photo of a factory setup?
Thanks!
Michael
Here is my 69. I had to search quit a bit before I found a source identifying the terminals. Can't remember where I found it. Spade goes to coil negative
I just made a google search MALE SPADE TERMINAL STUD or something like that.
Not sure why you couldn't use a ring term instead of a spade. Did you try your local hardware store for that spade? My True Value store has a lot of electrical stuff in drawers, that's where I got my spade piggybacks.
Any local electrical supplier should have those. If not, web electrical suppliers able to sell smaller packages or blisters. eBay too.
but...for me I have the factory original harness and I don't want to hack it up...trying to keep it as stock and stock appearing as possible.
I found an factory original ring lug with male spade. All is well.
