68' RR Trunk Finish Panel...Fender Tag Code ?
stuka1166
7:11 PM
Mid-Michigan
Is there a fender tag code to denote the trunk finish panel on a 68' RR ?
Thanks !!!
No. As far as I know the RR only had one finish panel. There were no options for a RR. I'm open to debate on that. I know they're hard to come by.
If it came with the decor package then yes. Does the trunk lid have holes for it? I am using a satellite panel and painting in the red. Fender tag should show trim code. Post it and maybe we can help. Yes new they are $$$$.
Sent from my SCH-I435 using Tapatalk
The car was listed as a non-décor/radio delete option...The fender tag denoted D4S under TRM...Deluxe/Bench Seat/Silver-Black Interior
Yes but not directly. Look for F/0; code 360 Décor group. As the tail panel was included in the group, if the Décor group is coded on the tag, then the car came with the panel. I do not believe the tail panel was coded separately.
Décor group included the H4* trim and tail panel so....
Interior code of D4S tells us there was no décor package so no tail panel either.
Is The Trunk Lid Original With Holes?
Decklid is original...no holes.
Thank you !!
