SOLD 68 to 70 gas tank with sender
BeepBeepRR
12:25 PM
Atlanta,Ga
Feedback: 16 / 0 / 0
I have the tank I pulled out of the roadrunner. The only reason I pulled it out is because it had a small leak in the corner of the pinch weld. It has been sitting under my shed for months. The inside is in great shape and a new sending unit is installed. I was able to weld the area that was leaking. I'll post it at 100.00 but could use some big block valve covers and or a timing cover. I don't want chrome I already have a set of Edelbrocks that I hate. Some surface rust should be easy to remove. And I think the bottom has some sort of undercoating. It will need a new filler grommet. I don't even want to think about shipping it. The sending unit is a few tanks worth of gas old. So its not Brand new but newish. Here is a link to the grommet you will need. Grommet
IMG_1524[1].JPG IMG_1526[1].JPG IMG_1527[1].JPG IMG_1525[1].JPG IMG_1535[1].JPG
Where you at in Atlanta? I may be able to work up a deal with you....look for a PM
