'69 B Body 383 - I would like to add a fan shroud. Will this work?
MikeyM
12:43 PM
NorCal
Hi all,
'69 Super Bee with a 22" radiator, no AC. I'd like to add a fan shroud then, later, a fan clutch setup. I was looking at the below shroud but they're saying it will work for 440 only. However, the hole to hole measurements they provide are the same as I have, my fan is just under 18", and the opening for the fan in the shroud is 20". It sure looks like it would work to me.
https://www.classicindustries.com/p...-7cIqayI499n2HMVflxoCmcwQAvD_BwE&gclsrc=aw.ds
I also found this one that looks like it WILL work and it looks exactly like the one above but is about 25 bucks more. Anyone know if these are the same shroud?
Radiator Fan Shroud 22" 1969 B-Body & C-Body 440
Thanks,
Mikey
Those new reproduction plastic shrouds warp after a while, get a 1968 383 two piece metal one.
No, not overheating now. I like the fan shroud as they have definitely helped in warmer weather, while idling, on all cars I’ve had to this point. Plus, it cleans up the engine compartment a bit, and adds a degree of safety for meatheads like me, reaching around in the engine compartment with a running engine.
Mikey
