69 Charger Tire Size & Gauge Question
RonnieWest
New Member
5:05 PM
CA
Hi Guys
I have a 69 Charger and have 2 questions:
What tire size do you recommend with 15x7 & 15/8.5 rims?
Also, where is a good place to get good electric gauges I can swap out for my stock ones? I tried Auto-Meter but they don't make the stock sizes.
Thanks!
:beerchug:
Ron
I'm not sure anyone makes a stock sized gauge to put in a Dodge ralley cluster. As far as tire size, that will have a little to do with the offset on the wheels. Rears should easily fit a 275/60/15 IF you have at least 4" of backspace.
I had some 255/60s all the way round on my 69 1/2 car on 15X7 rims. But realistically I think those are to wide unless you're going for a roundie rounder look
I was going for the General Lee sizes... know what those are?
go with 235/60/15 and 275/60/15 - pretty much the norm and gives that slight rake look....
Gauges... noone i know of makes a drop in gauge set - the large gauges are 5" and the small ones are roughly 2"... hope that helps... if you want a different look have them converted to white face - I did this to mine and it makes it look VERY different.
235 60 15 front on 15 x 7, 275 60 15 on 15 x 8.5 rear....
Nice!!! Thanks...
I am going to do a custom gauge cluster to accommodate newer electric sizes.
:grin:
