markbob
Hello All
I started up the Coronet after moving it to its new home (airplane hangar)
I noticed the brake warning light flash and the pedal got very mushy.
A quick once around under the car showed no obvious leaks but I noticed that the bleeder on the front pax side wheel had the "nut" part of the bleeped missing
I also noticed what appears to be a greenish fluid (not unlike the color of anti freeze) on the bottom of the proportioning valve and on the bottom of the lower steering linkage grease fitting.
I had the brakes adjusted by a guy who had helped me with some ignition issues and I believe he may be responsible for the broken bleeder. Is this green stuff what that synthetic brake fluid looks like?
If so can that and dot 3 be mixed?
Could this be my problem?
Running the car and pumping the brakes seems to help extinguish the light but the pedal is still mushy.
Thx
Mark
Thx
Mark
