Hi all, I have 69 RR 440 i had recently purchased, when i got it it could only start from jumping selinoid with screwdriver. Since I found a cooked neutral safety switch harness changed that neutral safety switch in tranny, and ignition switch and key cylinder and solenoid also. It will crank now with key and start after a few cranks, but not easy, seems to me low or high voltage going to coil causing hard start.
But you jump solenoid with screwdriver fires up first crank
any ideas on this ghost ?
