dirtypamopar
Hey guys, I'm relatively new to the board and only have one full restoration (I have two Mopars) under my belt so I was wondering if I could get some suggestions. I have a 1969 Roadrunner that is for the most part stock. I recently added a Hotchkiss sway bar in the front along with a pair of SPC adjustable upper control arms and the tight ration steering box from Borgensen to improve steering and high speed handling. So far that has worked out great. I'm looking for help/suggestions in the following two areas:
1. Braking is still a struggle when I have to make more sudden or forceful stops. The rear end locks up well before the front end (which from my research is what I should expect with Drums in the rear Disc in the front). My question is, can I get better braking without ripping out everything (rotors, drums, front discs, master cylinder). In other words, is there a more modest upgrade I can try or that others can recommend that have worked for them. Right now I have a stock config.
2. The front end grabs the road great now with the upgrades I mentioned above but the rear end whats to kick out around turns if I accelerate out of the turn. I considered a rear sway bar but I'm not sure that is going to solve the issue. So far I have considered lowering the car and using some hotckiss rear springs to hug the road better but wanted to know if there were any other ideas out there before I spend any money.
