'69 Runner needs a kickdown linkage
eagleone1983
7:52 PM
utah
I need the kickdown linkage for an automatic 727. I'm not sure if it matters what motor I have but currently there is a '78 400 block stuffed in it but I have a '68 383 sitting on a stand. I have the upper rod and link but I still need the center and lower rods plus the link between those two. I'll take the whole thing if anybody doesn't want to part it out.Thanks.
I have 99% of what you are asking for with the exception of the part that connects the upper to the lower via a ball type joint, if interested let me know...
I'm not quite sure what you mean. It should be a three piece assembly (upper rod-link-center rod-link-lower rod-transmission link). I only have the upper rod and link which I have two of so if the links are the same I'm good there. I need everything else (link between the center rod and lower rod, center and lower rods). Is that what you have? If so let me know what you're asking. Thanks.
If you notice in the pictures below that the upper is silver and the lower is blue. These were a set but one side was painted with the car.
In one close up picture you see a silver ball joint and the threaded blue shaft, well there is a piece that attaches these two - which is missing. If you have any questions please let me know.
I hope this makes sense!
I was using these on a 70's 440 which I believe would work for you!
