69X
KB9GIB
10:54 PM
S.IL
Hi,looking for some help on 69 b body X. when the light's switch is on I'm getting both blinker lights illuminating if I pull the front blinker bulbs out the blinker lights quit illuminating I think it's a ground so I've been checking them with no luck yet any other ideas on this would be helpful.
Sounds like a switch issue to me actually, but it could be a ground.
The dash dimmer switch on these cars are notoriously susceptible to failure and what a lot of folks don't realize is that the dimmer switch also plays the part of wiring junction for a LOT of light wiring.
First thing for me would be to get a wiring diagram (factory service manual) or download them here:
http://www.mymopar.com/index.php?pid=27
Thanks for the info I will check out the dimmer switch I did hit it a couple times to see if it changed anything but it didn't probably will change it out. Thanks for your reply. KB9GIB
