slociviccoupe
hey, i have my triangulated 4 link almost finished. I have the lower bars paralell to the ground at ride height, lower bars are mounted in the frame rail with relocation boxes welded into the frame rail. Lower tabs are welded to the axle shock mounts integrated into lower bar mounts. standard universal triangulated 4 link style. Im looking for who will sell the upper link cross bar mounting bar and shock mounting bar seperate from their kit.
Or some measurements that will help me locate my upper links. also what is a good number to shoot for with pinion angle at ride height? I was told about 2 degrees is good.
i set up the rear using the leaf springs on lowering blocks, welded on the brackets and atatched lower links. This keeping the rear centered, at ride height, and correct pinion angle. now just need to get my upper links atatched to something and the coil overs in and i can get rid of the leaf springs.
