RT6PK
1970 Coronet R/T. Factory 440 6 Pack 4 speed, 1 of 97. Older ground up restoration on a mostly rust free body. Factory fender tag and broadcast sheet. Dana 60 rear end with a 3.54 gear. Power steering, factory tach, and six way driver seat. The motor is a non numbers matching date coded 1970 block. The original numbers matching block is included. The radiator, distributor, alternator, and power steering pump all have the correct numbers on them. Carbs are dialed in perfectly. Car starts right up, idles smoothly, and pulls hard through the gears. The only deviations from stock are a mild hemi grind cam, Pertronix electronic ignition conversion, (in the original distributor), TTI ceramic coated headers and exhaust, and the vintage Sun gauges. Original exhaust manifolds and exhaust are included. I have photos of the car from the restoration so that you can see that it was NOT a rust bucket. Car is located in NE Ohio. I will consider the right 2nd generation Viper GTS Coupe in partial trade as long as it isn't yellow. PM for more details. $65.000.
