70 Road Runner dust trail location
Charles Cook
10:48 AM
Gaston South Carolina
I have heard different answers on the location. I’m going to have mine installed this week and wanted to make sure they’re in the right location.
I have pictures of several 70 models and they are not consistent.
Any help would be appreciated. Thanks
Thanks Wayne. When I try to blow up the picture it gets blurry. If I PM you my email address would you mind sending it that way? When I print it off it may be a lot clearer. Thanks
I stole it from here one day a few years ago... not sure it'll blow up any better but I can zoom it out enough to read with a magnifying glass! LOL
My car is the Limelight car you pictured in your original post. If you do some searching, there is another thread not too long ago on this exact same subject.
The stripe does NOT come out of the center of the fake scoop. It comes out centered on the road runner script that sits on the scoop (which is not centered). If you center it in the scoop, you are forced to make the stripe go uphill to avoid the wheel opening on the front fender.
Hawk
The stripe does NOT come out of the center of the fake scoop. It comes out centered on the road runner script that sits on the scoop (which is not centered). If you center it, you are forced to make the stripe go uphill to avoid the wheel opening on the front fender.
Hawk
Yep, I committed on your car before, saying it looked correct. I appreciate all the help guys. I want it to be correct the first time.
OK, if you really want this right, here are a few more tips:
1) There are 4 pieces to the stripe on each side: scoop, door, fender and bird, so you have 8 total pieces in a stripe kit. The stripes pieces are NOT INTERCHANGEABLE and are specific, side to side. The bird sets the pattern for the stripe, then separate the pieces left to right.
I can't tell you how many stripes I see where left and right pieces have been put on the wrong side.
2) OK, life is in the details. When you install it, don't just slap the pieces on there. Look at the picture below and see the pattern made by the little "x" shapes. I made sure that pattern continues across the door seam; the distances between the little "x"s are consistent. This is not by accident! You have 4 seams you need to deal with (front and rear door seam on each side). Make sure the pattern is consistent across each of them - it will make the stripe look better.
3) As stated above, be sure the stripe starts at the correct spot in the scoop, centered on the road runner script (assuming that was put in the correct location). I suggest using blue painters tape of the same width and lay a tape "stripe" down on the car so it is straight and in the correct location. Once you have it right, lay two more tape lines tight above and below your tape "stripe". Now remove the center tape "stripe" and you have a nice guide for laying your stripe down.
I have put quite a few decals on, and this is one of the harder ones. The pattern is part of it, but it is hard to get it really straight since it is long and thin. Look down the stripe from the front of the car and from the hood scoop - this is much more effective to see how straight it is than simply looking from the side of the car.
4) make sure you have a good transition between the bird and first tape stripe. Again, look at the pattern and plan this out before laying the stripe down.
5) I started with the bird and worked my way backwards. Don't ask me for "correct" measurements of where the bird should start (i.e. how far from the front of the fender). From the research I did, it seems this was not consistent as these were slapped on by a worker fairly quickly back in the day. I simply chose a spot that looked consistent with most I had seen. Perhaps @dadsbee picture shows this, but I can't read it.
Your reward for doing all this right is that people won't notice all the little details (but they will if they are done wrong)!
Good luck.
Thanks Hawk, my 1/4 panels are original so the road runner script is in the right location. Sounds like a tough stripe to install. Thanks for the info. If you think of anything else please let me know. Thanks again.
like in the other thread, you posted about this subject
to or not to
