valiant512
Good solid project. Original bench seat, 318 auto car. Great body. No frame issues. Sheet metal-All it needs is trunk floor and some work @ lower right dutchman panel. Floor,engine bay,trunk ext's. trans x-member, doors 1/4's and fenders are good. Car has new 4 speed hump and torque shaft bracket welded in.
Needs windshield, drivers door hinges, a nicer interior (vomit green). Car bought in North Dakota, now just over the border in Morden Manitoba. Car comes with 70 383 long block for rebuilding, steel crank, 906 heads. 11" flywheel, bellhousing and 74 b-body 4 speed. Engine brackets and isolators. New hurst shifter and rods, boot and trim ring, torque shaft and linkages, pedals for 4 speed conversion. 8 3/4 housing, backing plates axles and 489 case 3.23 sure grip. Disc brake spindles and pin style caliper adapters. Buckets seat cores from 72 Cuda. RR style tailights. 2-15x6, 2-15x7 Rallyes w/ new trim rings ( no center caps). Maybe a few more small things. Purchased a 2011 Challenger, need space. Title in my name.
$7000
Morden Manitoba Canada
Please PM. More pics available.
$7000
