Can you not use the cheaper 73+ and just weld washers into the big holes? That's what I'm planning to do eventually when removing the 73+ ISO mounts in my 74... after thinking about that, I guess it depends on which sway bar your going to be using?
The 71-72 U-bolt spacing is different than the 73-74 plates because of the iso mounts. The distance from the perch center to the bolt holes is different and drilling new holes would put them right on a formed edge.
