Dibbons
- 2:55 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I need to choose between the two used sets of clips I have. One set has the metal piece almost flat against the plastic, the other is angled about 45 degrees from the metal. What is the factory orientation?
And to install the screw, is it necessary to dis-assmble the plastic piece from the metal piece and then re-assembly them on the car?
Are photos available showing them installed?
Thank you.
Thank you.
