nstyle73
This hood is extremely clean rust wise with only very minor surface rust and paint checking on the underside. The worst is pictured. All the corners are sharp and undamaged and the front peak is also straight. It does have one dent on the front driver's edge, a larger shallow dent that was filled in the center of the bulge and a couple other small dings that were filled at some point. A word about the pictures, I chemically stripped the hood to find damage or filler under the 3 layers of paint that looked like they were rolled on (the ugly picture with different colors). The spots are places that the first layer of paint didn't come off, (it was gold/brown covered by red then orange). It is not surface rust. It currently has a token coat of primer. The hood is not ready for paint and will need blocked to finish taking it down to bare metal and will need the filler worked, or I think a good hand could fix the dent without putty. All said, the hood is a relatively easy fix for a DIY with no rust issues. I found one with the insert hole, so I won't be using this at this time. Shipping details can be worked out from 62442. Asking $800
