challengersteve
You are buying a Trunk Lid for a 71 - 74 Dodge Charger.
This is the 73 - 74 style that has the slightly different key lock opening but could be used fine on a 71 - 72 if the later trunk lock was used.
This is in SUPER SOLID Condition with no rust damage at all.
The lid is very straight and fits the quarter openings fine and only has the one small dent as shown.
The outer skin is somewhat loose as is common and will need the inside sprayed with a expanding sealer to tighten it up. This is a very common issue with all the Mopar trunks and hoods of this vintage and is no issue to correct.
This is 350.00 plus shipping which should be in the 150.00 - 200.00 range Fedex depending on where you are.
I accept Paypal and credit cards over the phone.
Thank you very much, Steve Schweitzer
