Martin Shows
I'm in the process of gathering up the parts to convert my column shift '71 Satelliite to floor shift. Thus far I've located a nice used console and SlapStik shifter, torque rod and shifter rods. I see that there are several manufacturers of re-pop tunnel brackets, is there a template somewhere or a sketch that give the correct dimensions for installing the brackets? I assume that they would be located from the centerline of the torque rod for correct alignment for the shifter rods?
Thanks,
Thanks,
