71 B Body Chrome Window Trim Install
JG71B
10:41 AM
NE OH
Front and rear glass is now in the Charger and the trim is ready to go on, does it matter what piece I start with or is there a specific order installing each piece?? Appreciate any help
I have a 73 RR but I think it would be the same. For the front I started with the top sliding the 2 pieces together them popping them into the clips, then down the sides since the wide molding across the bottom slides into the side pieces then covers the bottom that covers the cowl. On the back I went bottom to top since the side pieces slide into the bottom ends then worked my way up each side then sliding the end together at the middle top popping them into the clips as I went. I know this post is a month old but thought if your all ready done it might help someone else.
