727builder
New Member
1971 Pro-street Satellite. I sold this car to a buddy back in 1998. He started off building it to bracket race. Then changed his mind to Pro-street it instead. He has owned 13 years. When i first got it was a original 46K mile car with 318/904. Super Solid body with very little rust. Floors, Trunk, And body has almost ZERO rust. Has some minor rust on the firewall where it set with the hood off before he started building it. Car has Never been wrecked. Still has the original bumpers on it.
Engine is a 30 over 440 with 6 pack replacement pistons
509 Mopar cam
Edlebrock Heads
Holley street dominator intake with 825 double pumper Demon carb. Aluminum Water pump housing and Alum water pump.
Milodon 7 quart oil pan with Windage tray
Arp Rod and main bolts
Melling HV oil pump
Comp Double roller chain
Hedman Hedders going into 3" Exhaust with Borla mufflers.
MSD DIST and 6AL BOX
I rebuilt the 727
It has a bolt in Sprag
Turbo-action MVB
4.2 shift lever
Deep Mopar Pan
9 1/2 PTC 3800 converter
Car is mini tubbed with Super stock springs moved in.
Rear end is a Dana 60 with 5.13 gears and Moser spool and axles.
15x5 Drag stars on the front
Rear has 15x12 Drag stars with 16.50x31 hoosiers quick time pros. They are Worn out.
Car was painted about 5-6 years ago but the paint is fading out on the roof, hood and deck lid.
Has Pro-ratchet shifter.
Engine and trans only has about 1-2 thousand miles on them since built.
Has 10 gal fuel cell in trunk, Batteries relocated to trunk.
I also Have new carpet for it but not been installed yet.
Needs headliner
Come drive it. Runs strong!!!!!!
$10,500.00 Questions?? M----------------------m
Possible trades on drag car????????
509 Mopar cam
Edlebrock Heads
Melling HV oil pump
I rebuilt the 727
Turbo-action MVB
4.2 shift lever
Deep Mopar Pan
Needs headliner
