72 Challenger front disc brakes on 69 Charger?
greenmonsta79
12:05 AM
Brazil,IN
Guy's I have a complete upper A-arm to lower Disc brake setup off a 1972 Dodge Challenger, will this fit on my 1969 Charger? Everywhere I have looked it seems they share the same part numbers. This would make it easy if I can just swap it all to do away with the Drums on the front!!!
It all interchanges.....no difference in the upper and lower arms between the two cars however, if the cars have sway bars, there will be a difference between them and how it mounts. K frame is also different. You will need to use the 69 setup if you want to keep the bar.
That's what I was hoping to hear, The 72' has a sway bar setup (still have all of it) Im not sure if the Charger does really have not looked at it that good yet!
In 1970, the sway bar and how it mounts were changed on both B and E cars....
