Flash
I have been tackling various hideaway headlights issues I have had on my 72 and here is the list of work previously done.
-Replaced headlight switch and dimmer switch as both were melted.
-Installed @Crackedback headlight harness
-Replaced under dash headlight relay
After I installed Crackedback headlight harness the hideaway doors opened and would not close after turning off the switch.
Next step I tried is installing a replacement Bosch relay.
Am I wiring it correctly? Is this the correct Bosch relay. I have it grounded at the steering column ground.
Lights both work but doors will not open or close.
Any other suggestions?
