72 charger
Tried to bleed the brakes the other day nothing came through the rear. Fluid comes out fine out of the Front calipers. took of the lines from the M/C fluid comes out fine. Took off the proportioning valve and nothing will come out the fitting where the rear lines attach but comes out fine everywhere else. I notice there are several other fittings with nut heads and took them off some debris in them, but all except one lets air travel through when blew into the valve. Which is located on the bottom side near the fitting for the rear brakes. Does this in some way control the flow or is there a way to try and fix this a new one from year one costs $135 seems a bit steep to me.
