72 BLUE 400
have a 72 roadrunner grille,needs some love but the hard parts are there,the center piece was cracked in half and some one plastic welded it back together,the drivers side headlight bezel has 2 of the upper screw hole tubes missing other wise nice,pass side headlight bezel has i screw tube missing and the front edge is chipped,the center mesh has one small crack in one of the honey combs other wise very nice,the brackets are in good shape with the usual pitting and a couple mounting bolts broke off in the mounting holes.very hard to find a mostly complete grille without breaking the bank,if you know how to restore these grilles then you see the value.asking $725.00 for everything pictures show the damage to all the pieces.located sw michigan.
