73 A833 synchro
Biopack
11:59 PM
Maryland
Doing a rebuild of A833 from a 73 Charger and saw mixed information on synchros. For example, up to 72 or up to 70 is different. Any clarification on differences so I don’t purchase the wrong version? What should I look for to ensure it is the correct parts? Thank you!
Go to Brewers site and read. The differences are explained.
Call them and they will help you. Good people
Well if your trans is the right year for your application, and is likely so if it has the two shifter mounts on the tail housing, (check the stamped trans ID number if you're not sure), it takes the later style wide slot synchros.
