Curt Chambers
I've been searching these threads trying to find the correct heater hose routing for a 73 Charger, 440, w/AC. The FSM only shows hoses for a Coronet, and then doesn't show the connection points. There's a zillion diagrams on the internet, but they are either for older Chargers or other models, neither of which matches my setup.
Can one of you '73 owners snap a couple pictures of your hose routing? I'm not so interested in the physical routing as in the correct connections. I don't know which port on my water pump housing goes to the inlet side of the control valve. Or which side of the heater core hoses goes to the through pipe on the valve. In some places I've read it doesn't matter, and other places that it does.
Thanks.
Thanks.
