73 Road Runner steering column
Dodge33
7:48 AM
Bellevue, Mich
I'm wanting to rebuild this RR 4 sp column, and want to find out who/where
do you guys buy a very good new turn signal switch from? I looked on Ebay,
and did not really find one of good quality. Also, does anyone know if a 70 B-body
column use's the same TS harness? Thank's for any, and all your help! Dodge33
70 unit uses a diff hazzard knob ( some earlier 71s too ) what won't match the collar provision on later columns. They also turn on pushing in the knob instead pulling out. Otherwise works and fits the same. They are hard to find since are not being reproed.
The TW-4 replacement switch is a generic replacement option for our car. Wiring is diff color and horn contact is a push in stud instead the original roller bearing, but they work. There is a Mopar unit which gets an extra harness for cornering lamps ( used just on C bodies ), that can be used on our cars without problem, just the extra pigtail will remain without use
MS111 by M&S
US made. around 45.00 I get them from my local NAPA but they are not in the NAPA system.
Probably have used around 10-15 in the last several years. Never a problem.
How you guys doing? How was Carlisle?
