'73 roadrunner 440 oil dipstick tube
jaygtx440
7:49 PM
PA
Has anyone else had an issue with the 440 oil dipstick tube installation. I have ruined two Mopar Performance chrome dipstick tubes and on the $60.00 flexible one that I purchased, the stick is binding. All because of those goofy '73 engine mounts. I'm sure there wouldn't be an issue with the old style mounts. Any suggestions? I've been stuck on this for quite a while.
You're not running a windage tray or aftermarket pan, are you?
Both have been known to get in the way of a stick from time to time...
It's the tube itself that is causing the issue I am having. Thanks for the reply
Perhaps a pic would help. Are you saying the tube is getting bent because of the engine mount?
