archerN
New Member
Hi all
Most of the cluster in my 74 Satellite was completely dead when I started it this morning (incl. Temp,Fuel,Oil,Brake indicator). I suspected a cluster regulator but there is barely any voltage (0.015v) at the 12v leg of the regulator socket on the cluster. I have 12v on both sides of the cluster fuse and the fuse is good. I moved on to the cannon plug and all the pins look good, no corrosion.
Are there any "usual suspects" in the circuit between the cluster fuse on the fuse and cluster regulator I should look for? The electrics in the car are stock except amp gauge bypass and LED tail lights/marker lights.
Any input is appreciated. Happy 4th![usflag :usflag: :usflag:](/moparforum/styles/default/xenforo/smilies/usflag.gif)
