SOLD 8 1/4 sure grip and 3.55 ring and pinion
chargehard
5:32 PM
Titusville, PA
Feedback: 9 / 0 / 0
good.tight 8 1/4 sure grip and nice 3.55 gears from a '91 dakota 300.00 plus shipping to the lower 48 from 16354 N.W. pa. DSCF2069.jpgDSCF2070.jpgDSCF2071.jpgDSCF2069.jpgDSCF2070.jpgDSCF2071.jpg
i also have another 8 1/4 sure grip center that has been gone through and re-furbished by a differential shop 225.00 shipped to the lower 48
will seperate, 100.00 shipped for gears, does not include pinion bearing and shim, 200.00 shipped for sure grip.
bridge16354
FABO Gold Member
300.00 shipped anywhere in lower 48 from port orange fla
as long as it's an 8 1/4, somebody on here should know how to tell for sure, anybody?
If your rear end looks like the one second down then it will work.
Hope this helps
How much for the sure grip?
thank you for the chart, should be a big help. second sure grip w/o gears is sold, i could remove ring gear and sell you first sure grip for 200.00 shipped.
What one is that? What all will I need to change mine out?
the one i still have is the first one pictured with the gears and will work with 2.71 and numerically higher gears, if this is what you have then the sure grip is a direct bolt-in replacement for your open carrier with no extra parts needed as both bearing races are there, new bearings are just good insurance
