Detective D
Hello
I am working on my Police Monaco(78, B body) and guy I got it from used the 9.25 rear locker axle in his 74 Charger. On the plus side, he put the 8.25 from his Charger back onto my Monaco. But, the 8.25 is an open rear and it has a different ratio then stock. But, a guy an hour away had a correct 9.25 locker out of a big block b body with correct 3.23 gears so I have that now. Going through it right now.
So after that mouthful, the axle I have to put in has some obvious rust issues, namely, the back plate for the brakes on one side is completely gone and the other side is so bad I can't use it. The 8.25 under the car right now has PERFECT brakes, all solid, nice working condition. So the obvious question then is:
Can I take the entire drum brake system off that 8.25 and move it onto my 9.25? Do the back plates share the same mounting hole spacing? is there some other difference I don't know about preventing this?
I did a disc conversion on my 1990 Ramcharger and love it, but the prices(like everything) for that kit have gone up like 30% so I would rather reuse my existing nice stuff if I can. if I need to buy all new brakes, i will probably just pull the trigger on the discs next spring.
Anyone done this before?
