GrabberOrange69
I recently purchased a 3.23 SureGrip to replace the 2.93 peg leg in my '65 Coronet. In a "rookie" move, I assumed since both housings were 2070741 housings, the yokes would be the same. In fact, the u-joint straps appear to interchange. Now that the PIG is in my housing, I realize the distance across one yoke is 3 1/4" while the other is 4". Solutions....
1) Can I swap the yokes, i.e. will they interchange? If I did, will I have to set pre-load and back lash again?
2) Is there a "swap" u-joint I could use?
3) Will I have to get a new yoke on the drive shaft to match the housing?
I have unscrewed myself from the ceiling, accepted my fate, and I'm ready to listen. Thanks in advance!
