I'm about ready to begin assembling my rear axle and I'm still a bit confused over which gaskets go where at the wheel bearings. I suspect the gaskets that were in it when I took it apart were not completely correct.
I found the foam gaskets. I assume they go between the brake backing plate and the axle bearing retainer flange. Is this correct?
I haven't found a gasket for between the housing end and the brake backing plate. I've read it is metal with a rubber coating or bead. I have some gasket material (probably 1/32 inch thick I think. Any reason I can't just cut some gaskets out of that for this position?
