66 and 67 should be the same.The length of the 68-69 axle listed in the Super Bee ,Charger,Road Runner restoration guide measures 29-7/32" long and housing59-29/32" flange to flange.
The whole axle housing assembly should work and you may not even notice, unless you're almost rubbing your tires on the inside wheel well. OTOH, if you're almost rubbing on the outside, you'll be better off.
