zigs
Were
all B-body 8-3/4 axles adjustable. if not what years were.
So by my picture can you tell if this is pre 65 or not? Its out of a Belvedere. Previous owner said it belonged to his dad but didn't know what year , must have been detached from the car when he got it.
That lock placement is wrong? Easy enough to switch. Thanks that helped a lot.The lock is supposed to be on the bottom stud. Kim
Also doesn't matter which stud the adjuster lock is. Set your backlash and put the adjuster on the stud where it fits best.
I had already backed nuts off , thought I'd better ask the question before I got too far along.I always found the adjuster lock positioned at 2:00 stud and held down with that washer head nut shown in #1 post on the 2:00 stud.
Yes, those adjuster nuts are not drawn down enough on the studs.
Mike
Dial indicator is best; after you set it and try the end play, you’ll feel it move but not really see movement(if that makes sense).The 1966 Factory service manual states .013 to.023 for the axle shaft end play. Usually a dial indicator is used to set the clearance. Most just go by feel.
