493charger
I have a '68 Charger that has a 742 posi. The pinion seal was leaking and I got a new one, but when I removed the yoke I found more damage. The outer pinion bearing is junk, and who knows what else. I have another complete 8-3/4 with a 489 posi out of a '69 Roadrunner that was rolled with only a couple thousand miles on it. My dad picked it up around 1970 and the rear end still had fluid in it until a few years ago when I was going to build it up for the Charger. But, it hasn't rotated in 40+ years and I'm unsure if the posi is still any good.
Here are my thoughts...
489
+ Stronger pinion
+ Posi has low miles
- Posi is most likely a cone type that isn't rebuildable, and has been sitting for years.
742
+ Clutch style posi unit that is rebuildable.
- Posi most likely needs new clutches.
- Slightly weaker pinion.
- I'm also not sure if there is gear damage or not
What if I use the 489 and swap in the 742's posi with a fresh clutch kit, bearings and a CSE?
489
+ Stronger pinion
742
