krcevs
Do I need to use axle shaft seals when using the sealed green axle bearings?
Krcevs
Krcevs
Why would you need the inner seals when the Green bearings use an o-ring to seal the housing keeping the oil in.....unless you just don't want the Greens to see any oil at all but they are a sealed bearing in themselves plus have the o-ring on the OD of the bearing. You don't even need the outer seal if you don't want to use em.
We always put the inner seals on every single green bearing conversion we do. As mentioned, they are included with the big kit if you get the whole thing. Are they needed? Maybe not. Are all 12 bolts needed to hold the ring gear on? Probably not, but I ain't leavin any out.
I didnt get any axle seals when I picked up my housing and new axles. i guess it cant hurt installing them. I only used 6 ring gear bolts on mine. Figured 12 was overkill! Lol!
Krcevs
skip the oil also and then you dont need the seals.
Skip the oil also and then you dont need the seals.
