Thanks for the response. I have heard they can fall out, if so can they be purchased.The sure grip clutch pack type is the one with the buttons. It is bolted together.
Can't adjust your axle end playI canCan't adjust your axle end play.
Trying to educate myself. I'm changing out my 741 3.23 for a 742 3.90. I understand now 741 has buttons 742 does not. Thank you for the knowledge
Depends I suppose where they fell out and if axle installer knows it before operating the car?Thank you. What problems will occur if they have fallen out?
What if only one side fell out????Sorry what I meant was concerning your question,
If the buttons fall out, you will not be able to set endplay.
If it was the drivers side? You might be able to screw in the right side far enough to to still achieve endplay, on that side??What if only one side fell out????
My big concern is a loose unknown ejected button loose inside the housing.If it was the drivers side? You might be able to screw in the right side far enough to to still achieve endplay, on that side??
What's your thoughts and recommendations on the uni button tune- up?
And well founded. Ive driven with them floating around but don't recommend it.My big concern is a loose unknown ejected button loose inside the housing.
Checked my 741 the buttons are thereSorry what I meant was concerning your question,
