roadrunnerman
Thought I would give you a list of what you are getting with the car. I will also fedex the list along with other paperwork to you when the time comes.
front&rear int panels
windshield and back window trim
hood inserts
misc tub (Tupperware) nuts,bolts,pedal pads,window crank handles, sidemarkers
4-speed shifter w/ boot
splash shields
hood release
wiper pivot arms
int insulation
wing windows r&l
filer panel
taillight lens r&l w/bezels
sunvisors
kick panels
a-pilar trim pieces
headlight rings
hood release support
hood insulation
heater hoses
vent cables
grille and headlight bezels
front bench seat w/headrest upholstery (new in box)
ashtray
heater control
switch panel w/switches
dash wiring w/ fusebox,ignition, reverse light
armrest w/backing plate f&r
rearview mirror
battery tray
upper int panels r&l
headliner bows
dash guage
glove box lid
lower dash pad
front and rear seats
shifter linkage
clutch assembly
wiper motor
wiring harness (engine bay)
door panel trim
hood silencer (new in box)
dash pad
e-brake assembly
bellhousing, clutch, flywheel. did not see the fork
back window
side glass r&l (door and backseat)
heater unit
4-speed tranny (833)
front and rear bumper
Everything is packed inside the car and wrapped and protected as best as can be. also did not see the center horn ring for the steering wheel in any of the boxes as I was organizing everything,
hood inserts
splash shields
hood release
wiper pivot arms
int insulation
wing windows r&l
filer panel
sunvisors
kick panels
a-pilar trim pieces
headlight rings
hood insulation
heater hoses
vent cables
ashtray
heater control
rearview mirror
battery tray
headliner bows
dash guage
glove box lid
lower dash pad
shifter linkage
clutch assembly
wiper motor
door panel trim
dash pad
e-brake assembly
back window
heater unit
