FOR TRADE A body 72 duster for ????
6:48 AM
south jersey
Hello all. I am seeing if anyone would even be remotely interested. Have a 1972 Duster Racecar for trade
Motor
340
H-beam Rods
mopar performance pistons
Edelbrock aluminum heads
Valves seats springs retainers keepers all redone to fit a bigger cam
Only running small cam for now .510/.510 cam new pushrods
35 passes on top end of motor bottom end 70
compressions 180 on all 8 cylinders
850 carb
new headers
msd box coil distrib.
Trans
727
shift kit beefed up inside 35 passes
body
Repainted last april
Car was brought down to bare metal no rust
does not have original dash in car, aluminum dash ontop of the original dash supports. ( have a dash that goes with it ) 72 dash
Gauges are new with all the wiring and in the car
new shift cable
Racing seats
All glass windows with chrome trim
Have 2 brand new Tri-City triple plated bumpers just arrived, they are going on car to be in the Philadelphia Auto show for 2 weeks
Also have 2 fiberglass bumpers to go with it
2 sets of original grilles one is original color 1 is all black
Sharktooth Grille as well in great condition all lights work.
Has just lenses in the rear for tail lights, I purchased the whole harned to make the orginal lights work along with housings and lenses
Trans cooler is new with 35 passes on it as well
Electric fan electric coolant pump all wired with switches and fuses.
Hood is fiberglass and only part on the car that is besides current bumpers on car 4 inch cowl.
More drivetrain
Whole front end was just recently don't with polyeurethane bushings new bump stops and upper lower balljoints
Front tires have 50 passes on them
rear tires are 27x10.5
Front and rear are currently drum brakes ( I have a whole front disc conversion that comes with it )
Rear is an 8 3/4 leaf springs moved in 2 inches has 4.10 Richmond gears along with a spool inside the pumpkin
Line lock setup for front brakes it is a jegs setup never had issues even with drums
Few extras I have
original Door panels from a 72 Duster front and back sets color black.
New carpet in the box ( front only ) for now
comes with both sets of bumpers new chrome and fiberglass
Both sets of original grilles
This car does not have a title to it. it is a racecar I have owned the car for quite a few years, can do a bill of sale or w.e is needed
Basically all I can think of at this point any more questions feel free to pm me, I do not get on much but pm's go to my email
Interested in 68 69 roadrunners or satellites.
Can add cash on top ( not a wholeeeee lot ) , can travel interested in roadrunners gtx's satellites anything else u have u can send me a few pictures you never know
For those of you on the east coast , the car can be seen at the Philadelphia Auto Show
if anyone is interested I can put cash on top. just let me know. have a big block 440 shortblock went 11.00 in a 4,000 lb car if interested
What does the car run? Any interior pics? What do you value the car at? you may have me interested.
I am intrigued as well. How about some engine and interior pix.
hello sorry for not getting back to you guys, I do not get on here very much, pms are best way because it sets an alert to my phone, I do not have a lot of pictures of interior and engine but I can get some in the next day or two.
currently I decided to pull the transmission pan before my race in a few week,s and found out the sprag blew apart. The transmission is being rebuilt with everything new, only good part was the case. will have new bolt in sprag clutches bands cheetah shift setup new pump new 9 inch convertor 4500 stall. will come with a transferrable warranty written by an actual transmission shop. x9.jpgx10.jpgx11.jpgx12.jpgx13.jpgx14.jpgx15.jpgx8.jpg
the blue inside was before being painted. the trunk area is when we made the setup for the fuel cell fuel pump and lines. battery is in trunk as well. The car is plumbed to support a big block which was the plan after I was doing building the big block, I got offered 8,500 before the car got painted and I dumped a decent amount into it. to each is their own worth what someone will pay for it and we all know we do not get back what we put in.
has different pan, the oil filter is now relocated altogether now for easy oil changes and does not go all over the headers lol the fram is just for mock up , always ran the real long deep mobile one oil filter.
Finally got the car backout after redoing the trans. Trans is now fully built bolt in sprag drums updated to a 4 clutch pack. literally everything inside is updated and built for racing needs 9inch trans specialty 4500 stall converter new installed as well
