gamercier
I located a 440 engine 9A306978 the casting date is 5-23-69. The casting date seams a bit late. What dates were the A12 cars built?
The numbers on the lower block(vin) is clear along with the casting date. The top pad is strange.I am a few days late to this thread. Thank you @dadsbee for pointing it out. Below are my comments to the above posts.
The A12 cars were built from 3/10/69 to 7/11/69, the last day of production at Lynch Road for the 1969 model year. The 329 and 426 dates we see on the fender tags are called program hold dates. No cars were actually produced on these dates. This is the same for the Superbirds with a program hold date of B30.
The actual build date of an A12 car can only be estimated by evaluating the fender tags and the component build dates. This data is then cross referenced with known non-A12 cars. This is why we are constantly searching for more data on Lynch Road tags and component build dates.
The Lynch Road broadcast sheets do not indicate the actual build date of the car. They do present the time of day it was printed, but not the day. The only plant I am aware of this applies to is St Louis. The Chrysler invoice date to the dealership is accepted as the day the car rolled off the assembly line and the true build date. Unfortunately, these documents are quite rare.
As for the original question asked by @gamercier, is the 5/23/69 cast date good. My answer is yes, as production of the A12 went on for 7 weeks after this date. Also, the late May casting dates are very common in the later A12 cars.
@gamercier, can you please let us know what the engine assembly date is on this engine? Based upon the data we have, my guess is around 6/12/69. Without the fender tag, I can only go by the VIN.
D
I sent an email to the Registry contact Email on Monday... No response..
